Emails in usermin not showing
Webmin version 2.101
Usermin version 2.001
Virtualmin version 7.7
Theme version 21.04
Package updates 17 package updates are available
hi i have setup a new server, i will try the email system, i can send and they are also coming back.
but the issue is when i login to the usermin i cannot see the mails in the inbox.
when i login via webmin > read user mail > user i can see all mails in the inbox.
its a default installation no configs are changed
what can i do?
Hmmm… Have you seen this thread?
yes, there are no rules. i can send and recieve mails when i go in webmin > read user mail > user
so its only in usermin the issue
The way you describe it sure does sound like a usermin problem. You have verified they are there. I don’t use Usermin except for testing when I set up the server.
The ONLY weird thing I could postulate is if you have a system user and a domain user with the same username. In the first case you wouldn’t need @domain.com as part of the Usermin login name. In the second case you would. So, if you are sure you are logging into the account you think you are, sounds strange.
i have installed roundcube, and its working, but not with usermin
i think its a issue in usermin
@staffselection @staff please fix this
You can control mail storage format for Usermin users in Webmin ⇾ Usermin Configuration: Usermin Module Configuration / Read Mail: Configure Module page.
