Huh I always seem to get email problems on a new install of virtualmin
Well this time emails are not been sent from sites and also I can’t connect using windows live mail
http://vodkaholic.co.uk/files/mail.log
this is my /var/log/mail.log
Not sure if this is the right log to show you guys ;/
Cheers
Eric
May 28, 2012, 2:26pm
2
That is indeed the correct log – however, it’s rather huge… it’d be great if you could show the logs that occur whenever attempting to send or receive an email that you’re having problems with.
I do see a couple of issues that stand out though – in one case, it doesn’t look like an email is being given a from address, and it’s using “shieldomega@debian.server”, which is likely derived from your hostname.
You’d want to make sure you have an FQDN as your hostname – which is in the format host.domain.com .
Also, I see this error towards the top of your logs:
host mta7.am0.yahoodns.net [66.94.236.34] refused to talk to me: 553 5.7.1 [BL21]
Connections will not be accepted from 86.6.56.216, because the ip is in Spamhaus’s list; see
http://postmaster.yahoo.com/550-bl23.html
That suggests that your IP is listed in an RBL. In fact, looking here, it’s listed in 3 RBL’s:
http://www.anti-abuse.org/multi-rbl-check-results/?host=86.6.56.216
That would prevent it from being delivered to a any mail server doing lookups at those RBL’s.
Hey Eric what hostname should I use? and how would I go about changing it
Eric
May 28, 2012, 5:36pm
4
You can use any hostname you want, it just needs to be in the FQDN format, and it should exist.
You can change it in Webmin -> Networking -> Hostname and DNS.
You can make sure it exists in Virtualmin -> DOMAIN -> Server Configuration -> DNS Records.
I don’t seem to have that option in networking Eric
http://i.imgur.com/GrCrt.jpg
( also is there anyway to get a email back when someone reply’s on a thread on this site? I can’t see to find the option anywhere) not a on topic question I know sorry
Edit = nvm I found the option hope it works
Hey I found it under
Webmin >> Networking >> Network Configuration >> Hostname and DNS Client
Ive added
debian.vodkaholic.co.uk
http://i.imgur.com/eeAu9.jpg
Would that be ok?
Cheers
Eric
May 29, 2012, 12:14pm
8
Sorry, that’s what I get for trying to remember the path to that option off the top of my head
Yes, changing your hostname as you suggested should work just fine (though you’d also want to add a DNS ‘A’ record as described above).
No worry’s
Eric am still not getting emails from the site
http://vodkaholic.co.uk/files/mail1.log
Here is a log from when I tryed to send a email
Cheers
Eric
May 29, 2012, 7:09pm
10
Your logs there all look good! I see several messages that were accepted by the remove server for delivery.
I don’t see any errors or problems in your logs.
You may want to verify that your emails aren’t in the spam folder, maybe they were flagged as spam for some reason.
