This is also in the procmail.log Timeout::_run: check: no loaded plugin implements ‘check_main’: cannot scan!
Check that the necessary ‘.pre’ files are in the config directory.
At a minimum, v320.pre loads the Check plugin which is required. at /bin/spamassassin line 413.
procmail: Program failure (255) of “/bin/spamassassin”
procmail: Rescue of unfiltered data succeeded
procmail: Unable to treat as directory “/home/innovanv/domains/filing.innovanv.com/homes/filing/Maildir”
procmail: Error while writing to “/home/innovanv/domains/filing.innovanv.com/homes/filing/Maildir”
procmail: Lock failure on “/home/innovanv/domains/filing.innovanv.com/homes/filing/Maildir.lock”
From lthompson@innovanv.com Tue Nov 9 14:35:23 2021
Subject: FW: Emergency walkways - Look ahead
Folder: Bounced 5163782
Time:1636468552 From:lthompson@innovanv.comTo:filing@filing.innovanv.com User:filing-filing.innovanv.com Size:5163782 Dest:/home/innovanv/domains/filing.innovanv.com/homes/filing/Maildir/ Mode:None
