My email was working fine on my server with multiple virtual domains,
except now and then I would get this error.
"refused to talk to me: 501 Syntactically invalid HELO argument(s)"
I was trying to set-up the HELO on my Postfix mail and broke something I guess as now the incoming email does not end up by the users.
The sending email does not seem to get an error so I guess its getting to the server and I can still send mail to other email addresses and that goes through.
Even if I used another email like yahoo it still does not come through.
I can log into the email accounts from Webmin so that seems to still be there, but if I send mail to my addresses and then check it tells me no new mail.
Also I noticed Virtualmin wont allow me to enable the primary email account for the users under their email & FTP setting, keeps going back to the NO selected.
Okay mailboxes are now showing their location on the server
and new mail does end up there
but Squirrel mail and trying to download mail still says no new mail.
Under Virtualmin I select the domain name that I want.
I select Edit Mail and FTP Users
on the list that shows I select the name of the user,
Under edit mail box I click - Email settings to open up is details,
I then click on the location given under - Inbox mail file
(I.E: /var/mail/xxx.xxxx.com)
This gives me a list of emails and there are new ones there(lots of them),I can click on one and view it to.
I was wondering if its not a problem with the system not identifying the read and unread mail on the server properly,
Maybe the email client thinks its all old mail.
But then should SquirrelMail still not show them to me.
Very confusing as it seems to all be working to the point of accessing the emails, somewhere the place its putting the email and the place the system goes to retrieve them for POP/IMAP for the emails is not the same.
Well that is in my humble opinion at least how I see it.
I was just curious is it possible that I am logging into a second mail pop on my server.
I usually used ???.com (the straight domain) this is how it defaulted
is it possible that now it is meant to be mail.???.com.
Maybe my this got changed in the mess-up
If so would the user still login and just get an empty mail box if both existed.
or is it not possible,
how can I check what my mail servers address is meant to be.
