i get the error TLS not available due to local problem while trying to send mail from thunderbird how to fix this does require a starttls certificate and if yes how to create it
We need to see the exact errors, and the related entries from the mail.log for the session you’re trying to initiate (don’t send the whole log, just start tailing the mail.log and then initiate your connection in Thunderbird, and send the half-dozen or so messages in the log that the attempt to connect generates).
take a look here and if you need something because i don’t know well what to do here please give me some more details what to give you specific details
These warnings mentioned in the log are not related to the issue you are facing right now.
I have find around the web this example:
EXAMPLE:
warning: No server certs available. TLS won’t be enabled
warning: Wrapper-mode request dropped from mail.server.com[X.X.X.X] for service smtps. TLS context initialization failed. For details see earlier warnings in your logs.
Also, your configuration file located in /etc/postfix/main.cf can give us some clue. Just remove your personal informations like your IPs and domains
I think that the issue will be related to badly configured SSL/TLS, Cert, etc.
