Dovecot Not Starting
OS type and version Alma 9.4
Webmin version 2.202
Virtualmin version 7.20.2
Webserver version NO CLUE WHAT THIS IS
I setup a new Alma Linux server and am getting the following error when trying to start Dovecot.
Aug 21 09:30:42 alma.XXXXX.local systemd[1]: Starting Dovecot IMAP/POP3 email server…
Aug 21 09:30:42 alma.XXXXX.local dovecot[3340940]: doveconf: Fatal: Error in configuration file /etc/dovecot/dovecot.conf line 104: ssl_cert: Can’t open file /etc/ssl/virtualmin/171863499615899/ssl.combined: No such file or directory
Aug 21 09:30:42 alma.sgpharma.local systemd[1]: dovecot.service: Main process exited, code=exited, status=89/n/a
Aug 21 09:30:42 alma.XXXXX.local systemd[1]: dovecot.service: Failed with result ‘exit-code’.
Aug 21 09:30:42 alma.XXXXX.local systemd[1]: Failed to start Dovecot IMAP/POP3 email server.
I had this exact issue and I fixed it
It was caused by an issue with my hostnames SSL.
These fixes assume it is your hostname SSL causing the issue.
Fix 1
  • Run System Settings --> Re-Check configuration and this should fix it.
Fix2
  • turn off the SSL for your hostname
    System Settings --> Virtualmin Configuration --> Configuration category: Setup Let's Encrypt SSL certificate for hostname = No
  • turn ON the SSL for your hostname
I keep getting this message when I try to enable it, as it was not enabled:
Setting up Let’s Encrypt SSL certificate for the alma.XXXXX.local hostname …
… failed : Failed to set up Let’s Encrypt SSL certificate for the alma.XXXXX.local hostname
Edit the file above and figure out what domain is causing the issue. the offendder will be on line 104
Believe it or not there are 103 lines…
the last line that is blank is 104, that means the entry just before is the problem. it should even tell you the domain name
There are no domains added yet as it’s a brand new server. And the last line of the file says:
!include_try local.conf
Are you that you looked at the right field.
Did you do them instructions I gave you above.
This should work out of the box. Let’s start with how you installed Virtualmin?
Is this a private server?
Does this file exist?
Try this command from a terminal window:
ls -lath /etc/ssl/virtualmin
If it is a private server and you tried to set up a let’s encrypt cert then it probably failed.
This is what my dovecot ssl setup looks like:
I’m thinking you/Virtualmin tried to set up an ssl cert for the default domain and it failed.
Try setting up a self signed cert and see if dovecot starts.
That did it thanks
