Hi All
I’m after some advice as I’m scratching my head trying to figure out this problem.
This isn’t a problem with Virtualmin, I believe its an issue with my forum software but i’m not getting very far with them. I do fully suspect this a problem of my own creation with fettling. I’m just looking for (many) different eyes to help me investigate the issue if you can. I.e where to look in virtualmin for the settings.
I’ve recently moved dedicated host provider and we didn’t have this issue on the old box (meaning i either fixed it or I’ve busted something on the new one:))
I have a dedicated box which I’ve setup myself, with virtualmin running mybb forum board. For whatever reason when I enable GZIP compression on my new install/migration(of the forum admincp specifically) I am able to see forumdisplay and threads. But i cannot view any posts.
Error:
The webpage at http://306oc.co.uk/forum/showthread.php?tid=27943 might be temporarily down or it may have moved permanently to a new web address.
Error code: ERR_CONTENT_DECODING_FAILED
Effectively from what I can tell, I’m getting my content ‘double’ GZIPPED and the browser (Chrome, IE, Firefox) all have a fit and cant read the page.
Really quick summary:
- Old server (running squeeze), no problems, GZIP enabled in ADMINCP forum runs happily and has done for 3+ years
Operating system Debian Linux 6.0.10
Webmin version 1.720
Virtualmin version 4.12.gpl GPL
Theme version 8.7 Time on server 08/Dec/2014 10:58 , Up 711 days, 10 hours, 49 minutes
Kernel and CPU Linux 2.6.32-5-amd64 on x86_64
- New server (running Wheezy), fresh install of our forum software (not migrated). Can enable GZIP in ADMINCP, no problem. Works like a dream
Operating system Debian Linux 7
Theme version 8.7
Time on server 08/Dec/2014 12:09 , Up 2 days, 22 hours, 45 minutes
Kernel and CPU Linux 3.2.0-4-amd64 on x86_64
I cant for the life of me figure out what’s wrong with the setup. Something must be I know that but i cannot see where i have gone wrong.
It seems as if I have a config option enabled in virutalmin somewhere to provide server level gzipp’d content, so when I enable the gzip functionality in our forum software, it understandably
has a fit. I say this because when i have gzip turned off on the forum software a quick scan says we are running gzipped content: http://checkgzipcompression.com/?url=http%3A%2F%2F306oc.co.uk
I’m not going to sit here and say there are “no differences” there are none I can potentially think of, but surely there must be. The only major one is we gone from running under mod_php to FCGId
Can anyone shed some light on where I can continue investigating this issue?
Any helps and tips welcome. Happy to provide any information required
Regards
Fooby
