Hi
I’ve installed Dotdeb PHP7 on Debian Jessie with great result on Drupal, Prestashop and Dolibarr, all running since earlier on mode_php with extensive use of .htaccess.
But now I can’t have PHP executing on new installations of PHP based applications. When I go to “Virtualmin / Server configuration” there is no option to choose “mode_php” under “PHP script execution mode” as it was before, there are just “CGI wrapper (run as virtual server owner)” and “FCGId (run as virtual server owner)” to choose. On top of that, when I choose one of those two options, the setting is not saved after I’ve clicked on Save. When I go back after I’ve saved, the checkbox for the option I’ve just choosed is empty.
The above is valid for all domains, for the old ones as well as for the new ones that I’m creating (but as said, the old ones are running just fine)
Can anyone tell me where the problem is; what have I done wrong?
All the best
Hans
Configuration
Operating system Debian Linux 8
Webmin version 1.821
Virtualmin version 5.05
Theme version Authentic Theme 18.10
Kernel and CPU Linux 3.16.0-4-amd64 on x86_64
