So hey there! The title says it all, here’s my domain: insight-os.com.br
DomainKeys Identified Email is enabled and the keys generated, but I still get neutral in check-auth@verifier.port25.com
Summary of Results
SPF check: pass
DomainKeys check: neutral
DKIM check: neutral
Sender-ID check: pass
SpamAssassin check: ham
Details:
HELO hostname: node.insight-os.com.br
Source IP: 104.223.78.144
mail-from: contact@insight-os.com.br
SPF check details:
Result: pass
ID(s) verified: smtp.mailfrom=contact@insight-os.com.br
DNS record(s):
insight-os.com.br. SPF (no records)
insight-os.com.br. 38400 IN TXT “v=spf1 a mx a:insight-os.com.br ip4:104.223.78.144 ?all”
insight-os.com.br. 38400 IN A 104.223.78.144
DomainKeys check details:
Result: neutral (message not signed)
ID(s) verified: header.From=contact@insight-os.com.br
DNS record(s):
DKIM check details:
ID(s) verified:
NOTE: DKIM checking has been performed based on the latest DKIM specs
(RFC 4871 or draft-ietf-dkim-base-10) and verification may fail for
older versions. If you are using Port25’s PowerMTA, you need to use
version 3.2r11 or later to get a compatible version of DKIM.
Sender-ID check details:
Result: pass
DNS record(s):
SpamAssassin check details:
SpamAssassin v3.4.0 (2014-02-07)
Result: ham (0.7 points, 5.0 required)
pts rule name description
1.4 RCVD_IN_BRBL_LASTEXT RBL: No description available.
[104.223.78.144 listed in bb.barracudacentral.org]
-0.0 SPF_PASS SPF: sender matches SPF record
-0.2 RP_MATCHES_RCVD Envelope sender domain matches handover relay domain
-0.5 BAYES_05 BODY: Bayes spam probability is 1 to 5%
[score: 0.0118]
