Hi, I tried to use the domain change features in webmin and now my Virtualmin won’t even start. Anyone here able to help me out?
I’m getting this Failed to open SSL key /home/thelundgren/domains/parked.thelundgren.com/ssl.key at /usr/share/webmin/miniserv.pl line 4434.
Job for webmin.service failed because the control process exited with error code. See "systemctl status webmin.service" and "journalctl -xe" for details.
Edit: I’ve managed to solve the above problem by commenting out the pages in `/etc/webmin/miniserv.conf´
Next problem. Apache won’t start.
totte@server:/etc/apache2$ sudo service webmin start Job for webmin.service failed because the control process exited with error code. See "systemctl status webmin.service" and "journalctl -xe" for details.
totte@server:/etc/apache2$ sudo service webmin status
● webmin.service - LSB: web-based administration interface for Unix systems
Loaded: loaded (/etc/init.d/webmin; bad; vendor preset: enabled)
Active: failed (Result: exit-code) since Wed 2018-11-21 13:39:08 CET; 2min 49s ago
Docs: man:systemd-sysv-generator(8)
Process: 5992 ExecStart=/etc/init.d/webmin start (code=exited, status=1/FAILURE)
Nov 21 13:38:55 server systemd[1]: Stopped LSB: web-based administration interface for Unix systems.
Nov 21 13:38:55 server systemd[1]: Starting LSB: web-based administration interface for Unix systems...
Nov 21 13:38:55 server perl[5994]: pam_unix(webmin:auth): authentication failure; logname= uid=0 euid=0 tty= rus
Nov 21 13:38:57 server webmin[5994]: Webmin starting
Nov 21 13:39:08 server systemd[1]: webmin.service: Control process exited, code=exited status=1
Nov 21 13:39:08 server systemd[1]: Failed to start LSB: web-based administration interface for Unix systems.
Nov 21 13:39:08 server systemd[1]: webmin.service: Unit entered failed state.
Nov 21 13:39:08 server systemd[1]: webmin.service: Failed with result 'exit-code'.
