Does “virtualmin check-connectivity” work reliably?
OS type and version Ubuntu Linux 24.04.1
Usermin version 2.102
Virtualmin version 7.20.2 Pro
Theme version 21.20.7
Apache version 2.4.58
Never used this command before but was wondering if this is valid output because of the fact that the site can be reached and sports a valid SSL certificate:
$ virtualmin check-connectivity –domain EXAMPLE.COM
    Status: 4 errors
    Error1: web : Website request failed : 500 Can't connect to EXAMPLE.COM:80 (SSL connect attempt failed error:0A0000C6:SSL routines::packet length too long error:0A000139:SSL routines::record layer failure)
    Error2: ping : Failed to ping IP address : Ping of 203.0.113.1 did not response in 5 seconds
    Error3: ping : Failed to ping IPv6 address : Ping of 2001:0DB8:85A3:0000:0000:8A2E:0370:7334 did not response in 5 seconds
    Error4: smtp : SMTP connection failed : Connection timed out
@Steini,
I’ve never actually used this feature before, but assuming it’s doing an ICMP request for the “ping” process, you’ll need to make sure you’re allowing inbound/outbound ICMP requests through your firewall, otherwise a “ping” will fail.
For other requests, assuming it’s using the “telnet” approach to connect to ports checking availability, make sure each of the ports you are testing “25 - smtp”, “80 - http”, “443 - https”, etc can get through the firewall as well (typically this is setup by default if these services are being used and otherwise work).
Apologies, should’ve mentioned that I disabled the firewall for testing purposes. Same result.
