[root@ccc~]# ping software.virtualmin.com
PING software.virtualmin.com (51.158.66.131) 56(84) bytes of data.
64 bytes from 131-66-158-51.instances.scw.cloud (51.158.66.131): icmp_seq=1 ttl=46 time=99.5 ms
64 bytes from 131-66-158-51.instances.scw.cloud (51.158.66.131): icmp_seq=2 ttl=46 time=99.4 ms
64 bytes from 131-66-158-51.instances.scw.cloud (51.158.66.131): icmp_seq=3 ttl=46 time=99.5 ms
64 bytes from 131-66-158-51.instances.scw.cloud (51.158.66.131): icmp_seq=4 ttl=46 time=99.3 ms
64 bytes from 131-66-158-51.instances.scw.cloud (51.158.66.131): icmp_seq=5 ttl=46 time=99.8 ms
64 bytes from 131-66-158-51.instances.scw.cloud (51.158.66.131): icmp_seq=6 ttl=46 time=99.4 ms
64 bytes from 131-66-158-51.instances.scw.cloud (51.158.66.131): icmp_seq=7 ttl=46 time=100 ms
64 bytes from 131-66-158-51.instances.scw.cloud (51.158.66.131): icmp_seq=8 ttl=46 time=99.4 ms
64 bytes from 131-66-158-51.instances.scw.cloud (51.158.66.131): icmp_seq=9 ttl=46 time=99.6 ms
64 bytes from 131-66-158-51.instances.scw.cloud (51.158.66.131): icmp_seq=10 ttl=46 time=99.4 ms
It was working when I left it. I’m rebooting it now. Will hopefully come back. I think we might be under a DDoS (usually I blame the host, but it looks different this time). I’ll poke around some.
