Continuing the discussion from Default nginx document root for new virtual servers:
SYSTEM INFORMATION | |
OS type and version: | 20.04 |
Unfortunately the link at this thread is dead (404).
So I like to know if it’s possible to declare something in the nginx-default skeleton, which is used in every new NGINX-Conf in sites-available.
What I try to do?
I want to put the document-root into an variable via:
set $docRoot/my_root;
root /$docRoot;
But the path should be not hard-coded, but the one, NGINX would anyway set as default server path
It’s needed because I want to create location-directives in seperate conf-files, which should be included into the user-conf:
include /etc/nginx/conf.d/staticRootPath.conf
An in there in this file, I want to use:
# static files for nginx (not for apache)
location ~* ^.+\.(jpg|jpeg|js|png|css)$ {
root $docRoot;
