I have a case where, for example, the following domains are aliases, and each of them has its own DNS zone: example.com
example.eu (alias of .com)
When editing a record in example.com (the primary one), it deletes a record (it is not very clear whether it is random) from example.eu. The records between the zones are not in sync, and there are records that exist in one zone but not in the other.
Is this a bug, and what could be a potential solution?
user@server:~# grep -Rsi "If enabled in the template, add webmail and admin records" /usr/share/webmin/virtual-server
/usr/share/webmin/virtual-server/feature-dns.pl: # If enabled in the template, add webmail and admin records
When an edit is made to the main zone (example .eu) whether adding or deleting a record, there are records in the (example .com) zone that automatically disappear. The editing of the main zone is performed through the virtualmin panel (not webmin).
The user who makes the changes has sudo privileges.
The problem even persists If a change is made from the console, with sudo user using command:
"virtualmin modify-dns --domain “example.eu” --add-record "
