I seem to have problems with a domain which I moved across to a new server.
through webin I see the config file has the following:
zone "parstrust.co.uk" {
type master;
file "/var/named/parstrust.co.uk.hosts";
allow-transfer {
127.0.0.1;
localnets;
yet when I look for the hosts file I see it at
/var/named/chroot/var/named/parstrust.co.uk.hosts
recursive bit:
webmin - servers- bind dns server- Addresses and Topology- Allow recursive queries from- check listed and fill in localhost, 127.0.0.1
click save.
then go to Miscellaneous Options - Do full recursive lookups for clients? check yes.
Glue is adding A records to your host file.
webmin - servers- bind dns server- click the domain- add to Address Records
probably something like ns1.domain.com 111.222.333.444 (your IP)
