yes im sure i dont have any errors now … i made the test and putet back the empty line … i dont see any problem now … i think the problem is with this lines in the main.cf
cause these lines i copied them from internet and i dont know if they are good ?
for SMTP-Auth setting
smtpd_sasl_type = dovecot
smtpd_sasl_path = private/auth
smtpd_sasl_auth_enable = yes
smtpd_sasl_local_domain = $myhostname
smtpd_sasl_authenticated_header = yes
Replace this with your SSL certificate path if you are using one.
smtpd_tls_cert_file = /etc/postfix/postfix.cert.pem
smtpd_tls_key_file = /etc/postfix/postfix.key.pem
smtpd_tls_CAfile = /etc/postfix/postfix.ca.pem
smtpd_use_tls = yes
smtpd_tls_auth_only = yes
smtpd_tls_received_header = yes
smtpd_tls_session_cache_timeout = 3600s
smtpd_tls_loglevel = 3
tls_random_source = dev:/dev/urandom
Uncomment the next line to generate “delayed mail” warnings
#delay_warning_time = 4h
will it be a permanent error or temporary
unknown_local_recipient_reject_code = 450
how long to keep message on queue before return as failed.
some have 3 days, I have 16 days as I am backup server for some people
whom go on holiday with their server switched off.
maximal_queue_lifetime = 7d
max and min time in seconds between retries if connection failed
minimal_backoff_time = 1000s
maximal_backoff_time = 8000s
how long to wait when servers connect before receiving rest of data
smtp_helo_timeout = 60s
how many address can be used in one message.
effective stopper to mass spammers, accidental copy in whole address list
but may restrict intentional mail shots.
smtpd_recipient_limit = 16
how many error before back off.
smtpd_soft_error_limit = 3
how many max errors before blocking it.
smtpd_hard_error_limit = 12
This next set are important for determining who can send mail and relay mail
to other servers. It is very important to get this right - accidentally produ$
an open relay that allows unauthenticated sending of mail is a Very Bad Thing.
You are encouraged to read up on what exactly each of these options accomplis$
Requirements for the HELO statement
smtpd_helo_restrictions = permit_mynetworks, warn_if_reject reject_non_fqdn_hos$
Requirements for the sender details
smtpd_sender_restrictions = permit_sasl_authenticated, permit_mynetworks, warn_$
Requirements for the connecting server
smtpd_client_restrictions = reject_rbl_client sbl.spamhaus.org, reject_rbl_clie$
Requirement for the recipient address. Note that the entry for
“check_policy_service inet:127.0.0.1:10023” enables Postgrey.
smtpd_recipient_restrictions = permit_mynetworks, permit_sasl_authenticated, re$
smtpd_data_restrictions = reject_unauth_pipelining
require proper helo at connections
smtpd_helo_required = yes
waste spammers time before rejecting them
smtpd_delay_reject = yes
disable_vrfy_command = yes
milter_default_action = accept
milter_protocol = 2
smtpd_milters = inet:localhost:8891
non_smtpd_milters = inet:localhost:8891
smtpd_tls_mandatory_ciphers = high
otherway i cant recive emails from outside the server … when i send a test email to me … i recived it but when i send a test email to me from hotmail i dont recive anything and after oneday i get a delay email from hotmail
Delivery Status Notification (Delay)
what can i do know for the dkim sorry but realy i dont have any idea to solve this problem i hop u can help me with that
thanks alot
