SYSTEM INFORMATION | |
OS type and version | Ubuntu Linux 20.04.5 |
Webmin version | 2.021 |
Virtualmin version | 7.5 |
hello, i did read how to setup DKIM and dmarc but still they aint working for some reason, i check them on “mxtoolbox” plz check the pictures… | |
Imgur: The magic of the Internet | |
i fixed the Dkim the owner of the post i talked about told me but i still have an issue with the dmarc its not enabled… |
Read the forum for solution (before posting), recent chat about it
ik, but it still have an issue with the dmarc?? can u help (look at the pic)
Sorry, saw the mention for DKIM, should read fully.
That easy you have p=none, that disables any action, like a monitor status. set p=quarantine (failure of policy then mail goes to spam box) or p=reject (failure of policy then mail is rejected), best to set to quarantine first before moving to reject.
mxtool does fully explain that.
thanks, can u also help me with this
im fixing them for this issue Im using roundcube (server) but it only receive emails, it does not send any
rn i fixed SPF and DKIM and dmarc but the issue stilll there my this 2 palce issue are the cause!
They more warnings then anything major to worry about. It won’t effect mail delivery. Read “more info” on mxtools.
check the mail logs (as you send a email) for fixing the roundcube issue. Have you any emails in your postfix queue (that can be found under webmin-servers-postfix)
didnt really understand what u mean…, u mean if i created new emails from edit users??
You said it does not send (in roundcube) Create a new email to send and when you do monitor the mail log on the server for any issue. If they not sending they probably getting queued.
check here to see if they are, normally the reason its not send will show in there as well.
Those warnings are wrong, as I recall it. They insist on date format, but nothing in the spec requires a date…it just has to increase every time the records are updated. Feel free to change to date format in the Webmin BIND module configuration, but if DKIM isn’t working, it has nothing to do with those warnings (because those warnings should not be warning, if it’s the thing I think it is).
hello, i did sleep and its workign rn xD, i guess it just needed sometime to make the DMARC record and DKIM and SPF really work…
and thanks for ur help
and yes thats what did read about it so far in other websites…, and thanks for ur help
