| SYSTEM INFORMATION | |
| OS type and version | AlmaLinux 9.2 |
| Webmin version | 2.101 |
| Virtualmin version | 7.8.2 Pro |
| Related packages | SUGGESTED |
Below is a screenshot of the installation sequence and the problem presented:
@Ilia
Can you identify the problem presented?
Yes, for now you shouldn’t use ' in database password.
I appreciate your comment.
I reduced the difficulty of the password and it was installed correctly.
Thank you
Next release of Virtualmin will include the fix for Django install script to make it done correctly even when passwords contain quotes.
