Difference between GPL and Pro?
Is there a comparison chart anywhere?
I assume that the free version can be upgraded to the Pro version easily? Is this the case?
Many thanks
There’s a comparison available here:
http://www.virtualmin.com/compare.html
It is indeed simple to move from the GPL to the Pro version. There’s a link within Virtualmin that you can click labeled “Upgrade to Pro”, where you input your serial number and license key – and it will convert your current installation over to a Pro installation.
If you have any other questions, feel free to let us know.
