If I try to use:
virtualmin modify-domain --domain [a-domain] --ip [an-ip]
It breaks if the IP is already on the box:
ip addr add 10.226.13.9/22 broadcast 10.226.13.9 dev ens18 failed : Error: ipv4: Address already assigned.
Humorously if the IP is not yet on the box, when I run the same command:
It changes /etc/netplan/50-cloud-init.yaml from something like this:
network:
version: 2
ethernets:
ens18:
addresses:
- "10.226.144.99/22"
nameservers:
addresses:
- 10.226.13.1
- 10.226.13.2
search:
- fsr.com
routes:
- to: "default"
via: "10.226.1.1"
to this:
network:
version: 2
ethernets:
ens18:
addresses: ['10.226.13.9/22']
nameservers:
addresses: [10.226.13.1, 10.226.13.2]
search: [fsr.com]
routes:
- to: "default"
via: "10.226.1.1"
Which of course works just fine with the new IP… until a reboot, because the original IP isn’t there anymore and so does not answer.
That would be a super fun feature to find out about after a middle of the night emergency reboot three months after I’d run any such command!
Some forum hits:
https://forum.virtualmin.com/t/assigning-ip-address-via-shell/37806/3
https://forum.virtualmin.com/t/shared-vs-private-ip/37898/4
Mention using “–ip-already” for this, but I get:
Unknown parameter --ip-already
Whether I use it either of these ways:
virtualmin modify-domain --domain [a-domain] --ip-already [some-IP]
virtualmin modify-domain --domain [a-domain] --ip [some-IP] --ip-already
It seems like:
virtualmin modify-domain --domain [a-domain] --shared-ip [some-IP]
Does what I would expect that “–ip-already” used to do, but am I right about that? (It’s the “shared” thing in the name that throws me in this case because I am specifically trying to set a unique IP for a single virtual server in this case… so the opposite of a “shared”-IP.)
Does that “shared” infer some other configuration things that I might not notice right away?
Thanks.
| SYSTEM INFORMATION | |
| OS type and version | Ubuntu 24.04.2 |
| Virtualmin version | 7.30.8 |
