Hello
i install the virtual min with ./install.sh but i cant use thunderbird as email cleint . its working fine with roundcube. i check port is not blocking, selinux is disabled.
here is my email log
Feb 16 18:41:27 bluehorntech postfix/smtpd[29217]: connect from unknown[86.188.129.1]
Feb 16 18:41:27 bluehorntech postfix/smtpd[29217]: lost connection after CONNECT from unknown[86.188.129.1]
Feb 16 18:41:27 bluehorntech postfix/smtpd[29217]: disconnect from unknown[86.188.129.1]
Feb 16 18:41:39 bluehorntech postfix/smtpd[29220]: connect from unknown[86.188.129.1]
Feb 16 18:41:39 bluehorntech postfix/smtpd[29220]: lost connection after CONNECT from unknown[86.188.129.1]
Feb 16 18:41:39 bluehorntech postfix/smtpd[29220]: disconnect from unknown[86.188.129.1]
Feb 16 18:41:39 bluehorntech postfix/smtpd[29216]: connect from unknown[86.188.129.1]
Feb 16 18:41:39 bluehorntech postfix/smtpd[29219]: connect from unknown[86.188.129.1]
Feb 16 18:41:39 bluehorntech postfix/smtpd[29221]: connect from unknown[86.188.129.1]
can any one suggest what is the issue
