Default virtual server problem
Ubuntu 22.04
Virtualmin version Latest
Hello team, when i’m setup the virtualmin for the first time I complete my all steps but there was an setup for default virtual server which is haven’t asked on post intallazion wizard
My dashboard is opening on my IP address but i want it to be open on panel.domain.com
not really informative for help.
I thought there was some discussion about stopping this but it may not have been implemented yet. If you are using the nameserver panel.domain.com then you should still be able to login on the domain.com:10000 (your browser will probably object about not having SSL - but you should still be able to get there as http://)
Thankyou it works
