Default IP and external IP ?
I have two IPs on my VPS. in the control panel of the VPS (not virtualmin) I set one of them as the main IP. Virtualmin detects that as the external IP and says that is different from the default IP and it could be the result of NAT firewall. it says that when i re-check system. I need to make another virtual server on the second IP with a different domain. When I make the server and I set it to use the second IP, it says that the external IP is the first IP ( the main IP of my VPS) I guess for some reason all the virtual servers use the same external IP. So how do I make two virtual servers with different IPs each ? I don’t quite get the difference between external and default IP
It may be easier to adjust the settings in virtualmin configuration (networking settings) and tell virtualmin what to use as default IP. then put all the virtual domains on that ip
