I installed virtualmin, I try a ftp connection on port 21 with Filezilla but it doesn’t work
host : xxx.xxx.xxx.xxx
user : myname
on an other debian 9 server, I have just installed webmin and created an user and it work.
user : myname
Did you open that port on firewall? What is the message you have when try to connect? Proftpd is started and running?
I have only the firewall installed by virtualmin.
Filezilla return timeout only, no error message.
How I check if Proftpd is running ?
Can you share the exact error message you’re seeing when trying to connect?
A timeout often is firewall related (including any router that happens to be running in front of your server).
You can see what is running on port 21 with this command:
netstat -anlp | grep :21
I stopped FirewallD and it work
You can disable Firewalld and install something more easier to manage. I like too much of CSF and have module for Webmin, so you can managem your firewall without problem. I’m finishing my configuration of CSF and I can share here without problem. Commented too.
Or you just have to Open a port in Firewalld, running command line:
firewall-cmd --permanent --add-port=21/tcp
firewall-cmd --reload
To install CSF: https://download.configserver.com/csf/install.txt
Remember to disable and stop Firewalld before install CSF.
I have configured FirewallD and it work
