I have a Server Template that is supposed to install 3 apps. For some reason, it failed after 2, with a "DBI connect failed: Access denied", for the same user that seems to have installed the first two apps.
I seem to recall that there was a limit of two databases per virtual server somewhere, but can’t locate it in Server Templates (?)
One of the apps is Joomla in the root, and I can use Preview Website, so I know that the database is installed. In Install Scripts, I see the two apps and their databases. But under Edit Databases, the two script databases aren’t listed.
I’d appreciate any support in figuring out why the Template domain creation failed, as well as the database list anomaly.
Thanks,
Ken
