Custom System Logs - Where did we get too?
Usermin version 2.400
Webmin version 2.402
Virtualmin version 7.40.1 Pro
Theme version 25.10
Apache version 2.4.52
Now I know @Ilia rebuilt the system log package and added a load of stuff in but there is not option for adding custom ones where as in his earlier iterations there was:
I got loast half way in the developer converstation and just left it to them as there was some back and forth.
Is this somethign can can be added back in or was it decided that we could not have this feature?
I can add Extra log files to show but not premade jounalctl commands.
Related
Do you want to have journalctl commands configurable?
Yes please.
I can add legacy logfiles in the config, I think it would be reasonable to add my own custom journalctl commands, maybe not limited by the drop downs to allow completely user configurable ones and they are stored for use later.
What exactly would you like to have configured? What are you missing on the dropdown? I thought it covered pretty much everything.
I will dig out a specific one for you, it has been a while.
