It looks like there is something weird with MySQL Password management. Server creation stores the password if the authentication_string column whereas editing custom password updates the Password column.
The Custom password only is confirmed after the second try (maybe something to do with the pass_set thing ?)
Action : Server Creation
LOGS:
insert into user (host, user, ssl_type, ssl_cipher, x509_issuer, x509_subject, plugin, authentication_string) values (‘localhost’, ‘USER’, ‘’, ‘’, ‘’, ‘’, ‘mysql_native_password’, password(‘GLOBALPASS’))
State : MySQL Login works with DEFAULTPASS
Action : Set Custom DB password
LOGS:
set password for ‘USER’@‘localhost’ = password(‘CUSTOMPASS’)
mysql_pass=CUSTOMPASS
State : MySQL Login doesn’t work with CUSTOMPASS
Undo custom DB password :
LOGS:
set password for ‘USER’@‘localhost’ = password(‘GLOBALPASS’)
< mysql_pass=CUSTOMPASS
< pass_set=0
Action :Set Custom DB password (again)
LOGS:
State : MySQL Login works with CUSTOMPASS
Actually, i’ve seen the password being “randomly” ignored and I did have to set it again after resetting it.
Environnement :
Webmin 1.941
Virtualmin 6.08
Regards,
X
