|Operating system |Ubuntu Linux 18.04.6|
|Webmin version |2.105|
|Virtualmin version |7.10.0|
Hi, I haven’t poked in Virtualmin for several years, but wanted to install Stripe Plugin for a mate. Apologies if the formatting on this messy. The error for 2 different plugins:
Stripe Payments: following extentions are required by the plugin to operate properly but aren’t installed on your system:
curl
You need to communicate this information to your system administrator or hosting provider.
WP Simple Pay Lite requires
cURLto be installed.
So, it looks like curl is installed, though its an older version.
$ curl -V
curl 7.58.0 (x86_64-pc-linux-gnu) libcurl/7.58.0 OpenSSL/1.1.1 zlib/1.2.11 libidn2/2.3.0 libpsl/0.19.1 (+libidn2/2.0.4) nghttp2/1.30.0 librtmp/2.3
Release-Date: 2018-01-24
Also it looks like all PHP versions (7.2.34, 7.4.33, 8.0.29, 8.1.20, 8.2.7) are installed under Virtualmin > example.com → Web Configuration → PHP Options → PHP Information.
- Is there another place I should poke around?
- Could there be a security feature blocking curl?
- Do I need to upgrade my old curl?
- Is there anything else I might be missing
- What other information should i give (and how to access it via Virtualmin)?
I realise could just WP issue, but I’ve searched a few posts and saw that curl is needed with different payment processing systems.
Thank you in advance
