Hello all,
I face an issue with a cron job I have created in webmin. I have installed wp-cli (wordpress command line tool) in one of my websites. Also I have installed a plugin called wp all import which is making some imports from external xml files. Everything okay. The issue is that my cronjob is not working, even though the same command when I run it manually from cli is perfectly fine. I have tried to add the cron job inside the webmin area, Also added it in crontab -e with vim. I see the logs and I see that the cron exists there but it does not working. I am not sure if it’s a wp-cli issue or the cronjob is not working properly from the webmin settings. I will appreciate some help. Here are the cronjob command and also the log in /var/logs/cron
Jan 13 15:28:01 server CROND[965074]: (root) CMD (root /usr/local/bin/wp --path=/home/elekidis/public_html/ all-import run 2)
28 * * * * root /usr/local/bin/wp --path=/home/elekidis/public_html/ all-import run 2
Also an image of the schedules cron job tab
SYSTEM INFORMATION | |
OS type and version | AlmaLinux 8.8 |
Webmin version | 2.105 |
Virtualmin version | 7.9.0 |
SYSTEM | Intel(R) Xeon(R) Silver 4114 CPU @ 2.20GHz, 4 cores CLOUD VPS |
Related packages | SUGGESTED |
