Cron job is not running even after it says no output generated
I am unable to run the cron job through webmin but if I go to my website and run it manually it runs but webmin wont run it I am using Blesta and put the right cron command but it doesn’t work
I recently ran the cron manually by pressing that yellow button and this is the output that generates
Attempting to run all tasks for KiittenSMP Servers.
Attempting to apply credits to open invoices.
Attempting to apply credits for client group General.
Completed applying credits for client group General.
Attempting to apply credits for client group Server Cancelation.
Completed applying credits for client group Server Cancelation.
There are no invoices to which credits may be applied.
The apply credits task has completed.
Attempting to auto debit open invoices.
The auto debit invoices task has completed.
Attempting to deliver invoices scheduled for delivery.
No invoices are scheduled to be delivered.
The deliver invoices task has completed.
Attempting to provision paid pending services.
The paid pending services task has completed.
Attempting to process service suspensions.
The service suspension task has completed.
Attempting to unsuspend paid suspended services.
The unsuspend services task has completed.
Attempting to cancel scheduled services.
The cancel scheduled services task has completed.
Attempting to process service changes.
The process service changes task has completed.
Attempting to process renewing services.
The process renewing services task has completed.
Attempting to send payment reminders.
The payment reminders task has completed.
Attempting plugin cron for order accept_paid_orders.
Finished plugin cron for order accept_paid_orders.
Attempting plugin cron for support_manager poll_tickets.
Finished plugin cron for support_manager poll_tickets.
Attempting plugin cron for support_manager delete_tickets.
Finished plugin cron for support_manager delete_tickets.
Attempting plugin cron for support_manager send_reminders.
Finished plugin cron for support_manager send_reminders.
Attempting plugin cron for mass_mailer export.
Finished plugin cron for mass_mailer export.
Attempting plugin cron for mass_mailer mass_mail.
Finished plugin cron for mass_mailer mass_mail.
Attempting plugin cron for order process_abandoned_orders.
Finished plugin cron for order process_abandoned_orders.
All tasks have been completed.
Attempting to run all system tasks.
All system tasks have been completed.
You’re editing system crons. It is not “Webmin cron”. There is a module in Webmin for editing cron jobs, which is what you’re looking at, but it is not a cron specific to Webmin.
I’m not trying to be pedantic (though I see it might sound like that), I’m just trying to make sure you understand that troubleshooting a cronjob you setup in Webmin is the same as troubleshooting a cronjob you setup using crontab -e or a text editor or any other tool that can edit cronjobs.
I would start by removing the redirection to /dev/null so you get some output! (As already suggested by stefan1959.)
By the way… Are you sure you want an executable PHP file in the public Web directory? There are plenty of reasons why you might; but absent such a reason, it’s probably better off in /home/{user} (above the Web root in the hierarchy).
Output from command /usr/bin/php -q /home/kiittensmp/public_html/blesta/index.php cron …
Script error: the ionCube Loader for PHP needs to be installed.
The ionCube Loader is the industry standard PHP extension for running protected PHP code,
and can usually be added easily to a PHP installation.
Nevermind I fixed it I Literally just had to follow this guide How to install ionCube Loader - Wetopi but all i had to do was do part 3 Load the ionCube extension and run on of these
You should never do that. Wildly dangerous to run domain owner controlled code as root. Even if you trust that user, it’s still wildly dangerous because any exploit of the application becomes a potential root level exploit of your system. Never do that.
And, also, if all the deps are installed by a user into a user application directory and that directory is added to the user’s path or a otherwise made available to the user, root won’t have the same setup.
