Hi, excuse me, I’m trying to schedule a cron job to run this command “virtualmin transfer-domain --domain example.com --host replica.yourdomain.com --pass XYZ --replication --output --overwrite” but the job only start if I clic on “run now” inside the “Edit Cron Job” page of virtualmin. Are there something else that I should do to make this automatically?
Just to be sure it’s not a simple path issue (cron can be weird about paths), try using the full path to Virtualmin in your cron job… so rather than just “virtualmin”, try using “/usr/sbin/virtualmin” and see if that helps.
