jimr1
1
| SYSTEM INFORMATION |
| OS type and version |
Ubuntu Linux 22.04.4 |
| Webmin version |
2.202 |
| Usermin version |
2.102 |
| Theme version |
21.20.7 |
In the light theme cpu temps look like this
in the dark theme they look like this
I don’t mind which way they look as long as it is consistent across both themes
they cant look the same, dark theme/light theme.
Do you meant that core 4 is on a new line?
jimr1
3
That’s correct, that is the difference between the 2 images, mind you taking off 1px on the padding of the elements works
.badge-custom.xs, #system-status .badge-custom, .right-side-tabs .tab-pane .info-container .badge-custom {
padding: 1.5px 4.8px; /* was 5.8px */
If you get chance, have a look at the html/css and see if you can see any differences and post the code would speed it getting fixed.
