CPU temp + ID missing Dashboard
Webmin version 2.104
ODROID M1
There is no information about the CPU temp and Vendor in Dashboard.
Sensors is running correctly:
sensors
cpu_thermal-virtual-0
Adapter: Virtual device
CPU Temp: +39.4 C (crit = +95.0 C)
gpu_thermal-virtual-0
temp1: +35.6 C (crit = +95.0 C)
l
lscpu:
Vendor ID: ARM
Model name: Cortex-A55
Could someone give me tips?
Thanks!
Since there’s no standard for how this info is displayed, everything looks a little different. I guess we’re not recognizing this one in the parser. Here’s the code where that happens, I think: https://github.com/webmin/webmin/blob/c0bc9daff37157bd43207b221ee2d985925be7c9/proc/linux-lib.pl#L502
As you can see it’s quite messy, because nobody agrees on how to label and display this data.
@Jannock We could probably help in teaching Webmin parsing your specific output.
What is the output of sensors command on your system?
Thanks Ilia. The output of sensors is:
sensors
CPU Temp: +42.5 C (crit = +95.0 C)
temp1: +36.7 C (crit = +95.0 C)
This fix is here:
https://github.com/webmin/webmin/commit/a85fa2f8c281fd28e1a4a80c44d08231681be077
Thanks very much Ilia!
I did a package reinstall, but nothing changed.
You can try the following command to apply the patch:
cd /usr/share/webmin && curl https://github.com/webmin/webmin/commit/a85fa2f8c281fd28e1a4a80c44d08231681be077.patch | git apply --reject --whitespace=fix
… then don’t forget to restart Webmin manually using systemctl restart webmin command and at last force refresh system information using top right refresh button in the dashboard.
Does it show CPU temperature information now?
Thanks for your excellent answer. CPU temp is now visible!
I’m seeing the same issue described in this thread.
This is my sensors output on a Rockchip system:
soc_thermal-virtual-0
temp1: +43.5 C (crit = +115.0 C)
Do you know which version supports this format?
Could you help me with a patch so the CPU temperature is detected and shown in the dashboard?
Don’t make zombies. Start a new thread. You can link to this thread in your new thread, for reference.
