I am having a problem getting the corrrect temperatures for the CPU, it always shows 100 degrees C even when I run “sensors” command.
It is a virtual machine under ESXi 5.5 (maybe that is the problem) and I can see that the temps are around 35 degrees not 100.
Any help will be appreciated!
I am not sure what you mean…there are 2 cores of each CPU dedicated to the VM and it used to be working with CentOS and I don’t remember doing anything about it. With the “grade a” distros it isn’t…
