Correct way to redirect non www to www for the domain using Nginx webserver?
OS type and version AlmaLinux 9
Virtualmin version 7.20.2
Hi, I am a new user of Virtualmin. I have recently completed a fresh installation of Virtualmin on AlmaLinux 9. I successfully installed and created Let’s Encrypt SSL certificates for both example. com and www.example. com, and I have set all requests to be redirected to the SSL site under Virtualmin → Web Configuration → Website Options. Everything is working as expected.
However, I have been struggling to find a clear solution online for permanently redirecting the domain from example. com to www. example.com. Is there a way to configure this within the Virtualmin or Webmin UI? Thank you in advance.
@jahir3819,
For Apache based setup there is a section:
Website Configuration > Website Options
This page has a configuration as shown below to accomplish this task easily.
Failing that, another area that “might” be available (I don’t use Nginx with Virtualmin personally) would be under:
Website Configuration > Website Redirects
*** The first option actually indirectly configures a redirect on this page for Apache ***
Screenshot from 2024-11-09 23-01-57
Again, this is from a system that uses Apache NOT Nginx, though it’s possible the options are there and the system configures Nginx when it’s being used.
Let me know if this helps at all.
