has this been fixed? or has it fallen foul of some other update? As I find it it is still obscured!
Just check to see if your webmin and authtic theme are on the latest, mine still have not updated because I don’t think it has been pushed to the repo just yet.
I am running virtualmin and not a webmin only install.
Yes, it will be fixed in Webmin 2.201 release.
| SYSTEM INFORMATION | |
| OS type and version | Ubuntu Linux 22.04.4 |
| Webmin version | 2.111 |
| Usermin version | 2.010 |
| Virtualmin version | 7.20.2 |
| Theme version | 21.10 |
| Package updates | All installed packages are up to date |
Many thanks @Ilia that explains it. I thought I saw an update come through recently. But must have got confused (probably like many) expecting the theme to be updated at the time of A Virtualmin update ![]()
I guess I should pay more attention to error messages that flash before my eyes
I have done this a few times last couple of days
, but that is my bad. It will get released when it gets released
I think it is better to push changes to Webmin only users first so they can rule out any bugs and issues, then push to Virtualmin GPL so these user can then further revise any issues and then finally push to Virtualmin Pro as it is Virtualmin Pro users that are running commercial setups.
so release format should be:
Webmin only --> Virtualmin GPL --> Virtualmin Pro
Is it even possible to distinguish between Virtualmin GPL and Virtualmin Pro or even Webmin GPL? It is hard enough understanding Virtualmin vs Webmin as it is.
Dead easy.
- Webmin is the platform
- GPL = Free and community support
- Pro = Premium Support (if needed)
If you are using it to make money, get Pro = problem solved ![]()
Additional features
But I am going to suggest a lot more Pro features that will make a massive difference, one ideas was DMARC reporting, the graphs and such things.
There is no such thing as Webmin GPL. Webmin is licensed under a BSD license. And, there is no commercial version of Webmin (at least not from us, there have been many companies that shipped products built on Webmin, some of which have been proprietary).
