Connecting via IMAP
Webmin version Most recent
Virtualmin version Most recent
Hi team,
I have things up and running for the most part. I have 2 questions…
1; Am I not supposed to be able to ping the servers I add? I can access the web sites no problem, but pinging any domain / subdomain does not work.
2; I cannot seem to configure IMAP with Thunderbird. I tried auto detect settings and the usual settings you’d expect, but none worked. My mail log consists of things like:
Dec 7 09:21:44 DOMAINNAME dovecot: imap-login: Disconnected: Connection closed (auth failed, 1 attempts in 4 secs): user=USER@DOMAIN.tld, method=PLAIN, rip=IP ADDRESS, lip=HOST IP ADDRESS, TLS, session=
Dec 7 09:22:33 DOMAINNAME postfix/anvil[72215]: statistics: max connection rate 1/60s for (submission:107.170.252.64) at Dec 7 09:15:04
Dec 7 09:22:33 DOMAINNAME postfix/anvil[72215]: statistics: max connection count 1 for (submission:107.170.252.64) at Dec 7 09:15:04
Dec 7 09:22:33 DOMAINNAME postfix/anvil[72215]: statistics: max cache size 1 at Dec 7 09:15:04
Dec 7 09:24:44 DOMAINNAME dovecot: imap-login: Disconnected: Inactivity (auth failed, 1 attempts in 180 secs): user=USER@DOMAIN.tld, method=PLAIN, rip=IP ADDRESS, lip=HOST IP ADDRESS, TLS, session=<S/cR7uoLPuOpxya>
Dec 7 09:35:36 DOMAINNAME dovecot: imap-login: Disconnected: Connection closed (auth failed, 3 attempts in 18 secs): user=USER@DOMAINNAME.co, method=PLAIN, rip=IP ADDRESS, lip=HOST IP ADDRESS, TLS, session=
Dec 7 09:51:43 DOMAINNAME dovecot: imap-login: Disconnected: Connection closed (auth failed, 1 attempts in 4 secs): user=USER@DOMAIN.tld, method=PLAIN, rip=IP ADDRESS, lip=HOST IP ADDRESS, TLS, session=
Dec 7 09:51:52 DOMAINNAME dovecot: imap-login: Disconnected: Connection closed (auth failed, 1 attempts in 8 secs): user=USER@DOMAIN.tld, method=PLAIN, rip=IP ADDRESS, lip=HOST IP ADDRESS, TLS, session=
Dec 7 09:58:17 DOMAINNAME dovecot: imap-login: Disconnected: Inactivity (auth failed, 1 attempts in 180 secs): user=USER@DOMAINNAME.co, method=PLAIN, rip=IP ADDRESS, lip=HOST IP ADDRESS, TLS, session=
I find with Tbird you must use the settings as described
where the IMAP server hostname is mail.domain.tld
Thank you for the reply Stegan. It is working now.
