I’m getting the following problem when trying to configure virtualmin. I’m running CentOS5 in a virtuozzo control panel at eApps.com, so not sure if it is possible to use virtualmin?
First error :
Checking Configuration
Mail server Sendmail is installed and configured.
Apache is installed.
Webalizer does not appear to be installed on your system, or has not yet been set up properly in Webmin's Webalizer Logfile Analysis module. If your system does not use Webalizer, it should be disabled in Virtualmin's module configuration page.
If I then try to diable Webalizer as suggested I get this error :
Failed to save enabled features : No Ethernet interface could be automatically found on your system. Use the module configuration page to set the interface manually.
After that, I’ve no idea what to do, so any help would be appreciated!
Chris Howland
