Hello all,
I bought 2 Comodo Essential SSL for 2 of my clients, running on 2 different Webmin servers last version with all updates
Operating system=CentOS Linux 7.3.1611, Webmin version=1.831, Virtualmin version=5.07
I have followed instructions from https://www.virtualmin.com/documentation/tutorial/how-to-add-an-ssl-certificate
1, I created the CSR files from Server Configuration - Create Signing Request (Filled in the data needed) - Generate CSR Now
I’ve installed the CA send to me by Comodo from Server Configuration - Update Certificate and Key (pasted correct both Signed SSL certificate, Matching private key) - Install Now
I also created a new DigiCertCA.crt following instructions from http://howtodoit.eu/install-comodo-ssl-certificate-webmin-virtualmin-website/ and then Server Configuration - CA Certificate - (loaded correct CA certificate file) - Save Certificate
Server Configuration - Current Certificate - Copy to Webmin
Thought that this should be it
BUT
- when i go to https://solcore.eu/10000 everything is ok the SSL works ok and chrome tells me that its Secure
- when i go to https://www.solcore.eu or http://www.solcore.eu , chrome tells me that is not secure (This server could not prove that it is www.solcore.eu; its security certificate is from [missing_subjectAltName]. This may be caused by a misconfiguration or an attacker intercepting your connection.) searching further found that using self signed SSL form Webmin
on Server Configuration - Current Certificate i have:
SSL certificate file /home/solcore/ssl.cert
SSL private key file /home/solcore/ssl.key
Web server hostname www.solcore.eu Issuer name COMODO RSA Domain Validation Secure Server CA
Issuer organization COMODO CA Limited Expiry date May 9 23:59:59 2018 GMT
Certificate type Signed by CA
Other domain names www.solcore.eu | solcore.eu
and on Server Configuration - CA Certificate i also have
Certificate authority name www.solcore.eu
Someone please help, i have to install Comodo Essentials to almost 5 more sites on different Webmin installation each.
Regards George
- well feel free to pm me on google hangouts or
