First of all, thank you for a great product. If buying the pro version gives me the ability to do this, I’m ready to pony up.
I only have one IP available for my webserver, is there no way to host multiple sites on one IP? My server is actually behind my firewall running on 192.168.1.10 so the “real” IP is actually on the firewall. Is there anyway I can run mutliple ssl sites by creating more private IP addresses? Or maybe using a different port? I now about sli, but it’s not quite supported yet.
Any help or push in the right direction is greatly appreciated.
I meant, that my firewall only supports a 1:1 ratio for real world IP to private IP. So by additonal private, I also meant additional external.
Sure. That’ll work fine. You need one public IP per SSL virtual host, and it needs to map a private IP. I assumed the “COLO stingy with IP addresses” meant you couldn’t get those extra external IP addresses.
