Ok, about every 5 minutes, collectinfo.pl runs and it basically slams the CPU, and load. Load will be at about 0.45 and jump to 20.00+ when collectinfo.pl starts running. It seems to lock everything up until it is finished.
Perusing through the code, the only assumption I can come up with is that it is locking a file(s) somewhere that is needed by httpd, such as a log or conf file…
Never had much of a problem with it before… Last night I upgraded webmin, then virtualmin to the latest versions in hopes this would stop.
Is there some sort of log file it is choking on? Anything to look for?
It is getting to the point where I might just disable the job because it is bringing all the sites down…
It’s not locking any files that would prevent web service. I’m guessing it’s just overloading your box. I believe 3.49 should have made collectinfo.pl less demanding rather than more…nice is used to run it at the least demanding priority.
Any chance memory is a problem? If Apache gets pushed out to swap, it could make service quite slow.
Thanks, I really appreciate your reply!
It is possible, however this would be a new thing as it has run fine for about 6 months now. Really have not added anything new to the server and traffic is within normal parameters.
I disabled the cron job last night and my load stats are back to normal.
What adverse affects will this have on virtualmin if it is not running?
Not really any adverse effects, except you won’t have useful data on the system information page. collectinfo.pl is what gathers that data on a regular basis. This includes the historic graphs.
From root@--.net (Cron Daemon)
To root@--.net
Date Wed, 19 Dec 2007 07:15:13 -0500 (EST)
Subject Cron <root@--> /etc/webmin/virtual-server/collectinfo.pl
Message text
Error: Failed to query Postfix config command to get the current value of parameter
process_id_directory: <tt></tt>
Error
Failed to query Postfix config command to get the current value of parameter process_id_directory:
<tt></tt>
To root@--.net
Date Tue, 18 Dec 2007 00:10:03 -0500 (EST)
Subject Cron <root@--> /etc/webmin/status/monitor.pl
Message text
postfix::is_postfix_running failed : Failed to query Postfix config command to get
the current value of parameter process_id_directory: <tt></tt> at …/web-lib-funcs.pl
line 980.
My collectinfo.pl was running crazy too.
I upgraded from 3.52 GPL to the Pro, but that didn’t fix it.
I disabled it for now…if you figure it out, let me know.
The body of the emaill would repeat this about 20 times:
quota: Quota file not found or has wrong format.
I disabled quotas, and that still came every 5 minutes.
every 5 minutes even though quota's are disabled..
any idea?
sys info:
Operating system Debian Linux 4.0
Webmin version 1.420
Virtualmin version 3.60.gpl (GPL)
Kernel and CPU Linux 2.6.18-5-amd64 on x86_64
I’m having the same problem with collectinfo.pl taking my cpu to 100% every few minutes. It’s just recently started happening and I can’t figure out why. I don’t really see any answers here though.
I’ve had the system up and running for over a year without problem.
I'm having the same problem with collectinfo.pl taking my cpu to 100% every few minutes.
But, is it causing an actual problem? (A process taking all available CPU for a short time isn’t actually a “problem”. It’s just doing work. If it is interfering with other, more important tasks…then that would be a problem.)
Heheheh…Your first mistake was letting a server live anywhere near you. Ours are 1500 miles away.
You can turn off collectinfo.pl, or make it run less often. It is configured in the "Status collection" page in Module Configuration.
Its purpose is to gather information about the system…stuff like memory usage, CPU usage, quotas, number of virtual servers, etc. If you can live with out of date information on the System Information page, or nothing changes very often, then you could set it to run once per day, or similar.
