collectinfo.pl: Permission Denied
My Virtualmin install suddenly started throwing a
: Permission denied
error every 5 minutes when it runs the /usr/local/etc/webmin/virtual-server/collectinfo.pl via cron job.
I also get the error running it directly (as root) from the command line.
Any idea what could cause this? It gives me no more info than "Permission denied".
Please log into the shell of your server as root and perform the following command:
ls -l /usr/local/etc/webmin/virtual-server/collectinfo.pl
Then post the results.
hi
refreshing topic
i have also this problem
[code:1]
Received: by 1.ex.com (Postfix, from userid 0)
id CCA0450845; Thu, 1 Jan 2009 13:18:03 +0000 (UTC)
To: root@1.ex.com
Subject: Cron <root@1> /usr/local/etc/webmin/virtual-server/collectinfo.pl
X-Cron-Env: <SHELL=/bin/sh>
X-Cron-Env: <HOME=/root>
X-Cron-Env: <PATH=/usr/bin:/bin>
X-Cron-Env: <LOGNAME=root>
X-Cron-Env: <USER=root>
Message-Id: <20090101131803.CCA0450845@1.ex.com>
Date: Thu, 1 Jan 2009 13:18:02 +0000 (UTC)
: Permission denied
[/code:1]
ls -l results:
[code:1]ls -l /usr/local/etc/webmin/virtual-server/collectinfo.pl
total 32
-rw-r–r-- 1 root bin 317 Dec 16 22:19 bw-template
-rw-r–r-- 1 root bin 5833 Jan 1 13:13 collected
-rwxr-xr-x 1 root bin 380 Dec 16 22:19 collectinfo.pl
-rwx–x--x 1 root bin 3458 Dec 16 22:19 config
-rw-r–r-- 1 root bin 1027 Dec 16 22:19 domain-template
-rw-r–r-- 1 root bin 639 Dec 16 22:19 framefwd-template
drwx------ 2 root bin 512 Jan 1 13:13 history
-rw-r–r-- 1 root bin 16 Dec 16 22:19 installtimes
-rw-r–r-- 1 root bin 391 Dec 16 22:19 local-template
-rw-r–r-- 1 root bin 0 Dec 16 22:19 map.alias
-rw-r–r-- 1 root bin 0 Dec 16 22:19 map.dom
-rw-r–r-- 1 root bin 0 Dec 16 22:19 map.gid
-rw-r–r-- 1 root bin 0 Dec 16 22:19 map.parent
-rw-r–r-- 1 root bin 0 Dec 16 22:19 map.reseller
-rw-r–r-- 1 root bin 0 Dec 16 22:19 map.subdom
-rw-r–r-- 1 root bin 0 Dec 16 22:19 map.user
-rw-r–r-- 1 root bin 866 Dec 16 22:19 subdomain-template
-rw-r–r-- 1 root bin 416 Dec 16 22:19 update-template
-rw-r–r-- 1 root bin 380 Dec 16 22:19 user-template
-rw-r–r-- 1 root bin 359 Dec 16 22:19 warnbw-template
[/code:1]
thx for any information
guest
