Today I started getting periodic emails from collectinfo.pl saying that it is already running. There’s an issue in the tracker, but it’s marked closed with no comments:
https://www.virtualmin.com/node/2876
Any ideas?
Thanks,
Chris
Any ideas?
Thanks,
Chris
There are comments in there – the move to the new forum/bug tracker caused some issues with permissions
That particular problem turned out to be an issue with yum/up2date contacting the repository.
What distro and version are you using?
And can you attach the output of this command: pstree -l -p
Thanks,
I’m on Ubuntu 8.04 LTS. Looks like it’s the same problem – apt is timing out. Probably related to the 9.10 Beta release. Thanks!
