Collectinfo.pl frequency
Operating system Ubuntu Linux 16.04.7
Webmin version 1.973 Usermin version 1.823
Virtualmin version 6.16 Authentic theme version 19.73
I’m having some issues stopping the collectinfo.pl script from running every 5 minutes. I noticed that collectinfo.pl was taking a bit too much cpu for my liking so I wanted to reduce the frequency it ran to once per day instead of every 5 minutes. I went to virtualmin> system settings> virtualmin configuration> status collection > changed interval between status collection job runs to 1440 minutes. But the script still runs every 5 minutes. Is there something I need to do after changing the frequency? A specific cronjob I need to edit on the server? The webmin scheduled functions page doesn’t have any cronjobs running at a 5 minute interval so I’m not sure why it would be doing this. Thank you.
When you save Virtualmin Configuration → Status Collection page, does the value collect_interval getting changed/updated in /etc/webmin/virtual-server/config file?
If so, re-running config check will update scheduled functions run time.
/etc/webmin/virtual-server/config/collect_interval does not change, it’s set as collect_interval=5 after changing the status collection time again, is it safe to just edit this file and change it from 5 to 1440?
Yes, a key collect_interval on /etc/webmin/virtual-server/config file can be change manually but re-check config must be run to have interval being updated.
Wait, if you go again to Virtualmin Configuration → Status Collection page and update time there by hitting save, later go back to that page again (or click back and hit Alt+R to refresh), does it contain the new value or old?
Refreshing the status collection page showed that collection interval was 1440 minutes, while the config file said it was 5 minutes. I changed the config file to 1440 then did Re-Check Configuration. After the Configuration check both the website and config file say 1440. But collectinfo.pl is still running every 5 minutes.
Then you’re looking into different collection. Have a look at Webmin ⇾ Webmin Configuration: Background Status Collection page.
Yes, thank you I figured it was something simple. Webmin background status collection is set to 5 minutes, when I change to 1440 and press save it just says “Error” , no further details on the page. /var/webmin/miniserv.error also only says “Error:” when trying to save. miniserv.log gives me:
[24/Nov/2021:13:36:57 -0400] “POST /webmin/change_status.cgi HTTP/1.1” 200 4616
Sorry I’m not sure what’s relevant to try and give more detail here.
Is there some way to change this through a configuration file rather than the web interface?
Collection interval must be an integer between 1 and 60, otherwise it would make more sense to simply disable it.
Yes, check /etc/webmin/system-status/config and /etc/webmin/webmincron/crons/*.cron files.
I’d recommend simply disabling status collection in this case.
Also, you could go to Webmin ⇾ Webmin Configuration: Webmin Scheduled Functions page, click on the cron job and set an interval with specific times.
This finally got collectinfo.pl to stop running every 5 minutes, thank you. I also set Webmin ⇾ Webmin Configuration: Background Status Collection to never as you suggested. Thank you very much for your help.
