I don’t see a way to comment on existing bug entries, so I am posing a followup here to bug #35. If ColdFusion is too difficult to support because of their limited OS requirements, then you may want to take a look at BlueDragon:
My understanding is that this product can be used as a replacement for ColdFusion, and they even offer a free version of it. They have strong support for multiple Red Hat Linux versions (including Fedora and probably CentOS), and they have a J2EE version that should run on most other OSes:
Thanks for the heads up on this. I was not aware of it.
Yes, commenting on bugs isn’t working…there’s a bug about it.
We definitely will be adding some kind of support for ColdFusion, and we’ll have a look at BlueDragon. Sounds like it might be a good alternative for folks not using the couple of systems supported by ColdFusion.
