Cloudmin Installation Error
OS type and version Debian 11
Webmin version REQUIRED
Cloudmin version latest GPL KVM package on the webmin website
I am getting the following error when installing cloudmin on a fresh debian.
Building dependency tree... Done
Reading state information... Done
Package dhcp3-server is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'dhcp3-server' has no installation candidate
Reading package lists... Done
E: Unable to locate package libdigest-sha1-perl
The following NEW packages will be installed:
  ebtables
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 86.6 kB of archives.
After this operation, 271 kB of additional disk space will be used.
Get:1 http://debian.intergenia.de/debian bullseye/main amd64 ebtables amd64 2.0.11-4+b1 [86.6 kB]
Fetched 86.6 kB in 1s (170 kB/s)
Selecting previously unselected package ebtables.
(Reading database ... 42391 files and directories currently installed.)
Preparing to unpack .../ebtables_2.0.11-4+b1_amd64.deb ...
Unpacking ebtables (2.0.11-4+b1) ...
Setting up ebtables (2.0.11-4+b1) ...
Processing triggers for man-db (2.9.4-2) ...
.. done
Installing and activating cgroups ..
Package cgroup-bin is not available, but is referred to by another package.
However the following packages replace it:
  cgroup-tools
E: Package 'cgroup-bin' has no installation candidate
.. install failed - CPU limits will not be available
Activating KVM kernel module ..
.. done
Creating /dev/loop devices ..
.. done
Installing Cloudmin packages using APT ..
E: Unable to locate package webmin
E: Unable to locate package webmin-server-manager
E: Unable to locate package webmin-virtual-server-theme
.. install failed
@Jamie Same issue here
I found a resolution for it for now.
apt install pgp
then run the installer again.
Does it now run to completion ? or is it failing on QEMU now ?
