| SYSTEM INFORMATION | B |
| OS type and version | Rocky Linux 9.3 |
| Webmin version | 21.05 |
| Usermin version | 2.005 |
I created a new category. I cloned custom commands module and called it “Authentication” and I put it under my new custom category. I clicked that the custom command should be available under Usermin when building the new custom command. The new category NOR the newly cloned module are showing up in Usermin after I log off and back onto usermin. I can assign a cloned module to usermin under the same category and it shows up. But the custom commands won’t move over. Even the pointer to the Webmin custom command gets created but there’s some kind of linkage broken where the custom command I built in Webmin doesn’t show up in usermin. All this used to work. Now it seems to be a broken functionality. I even did this with a fresh install of rocky on a vm and brand new webmin/usermin installs. I can’t get that custom module and command to show up in usermin. Please advise. Let me know if any further info is needed.
