Message about the missing doc, just seen your warning and the URL of the legacy one, Thanks!
Indeed it is
Those documents are all auto-generated, and Joe has been working on getting the scripts to work with the new site.
In the meantime, if you run the command “virtualmin” on the command line, you’ll see a list of available options.
Yell if anything in the command line output doesn’t make sense!
