I have just noticed that Classic Press is creeping into my Wordpress installs/servers.
We had this a year or two ago and it was sorted, but is back!
Do you mean you have users that have installed Classic Press?
Are you allowing Classic Press from available web app installs?
NO. Wordpress is installed. ClassicPress just appears. It is sharing the WP DB!
ok, just could not understand (and still don’t) the problem from first post.
How did you sort it out last time?
I didn’t - it was sorted out in an update.
I don’t understand what that means, and I don’t remember a previous discussion about it.
Where does ClassicPress “just appear”?
Hi, ClassicPress is a separate fork of WordPress, so it may just be showing up in the Virtualmin script installer list again, possibly after an update reset your settings. Can you check whether it’s only listed as an option or actually installed on your domains? If it’s only listed, you can disable it in the script installer settings in Virtualmin.
@leoadam2772
Have to wait and let the OP explain more of what the actual problem is.
I have never installed Classic Press.
It has appeard on a server, using the same DB as Wordpress.
I reported this last year (or two) and it was resolved (either on the forum or a via support).
It has now come back and has put itself on 7 domains/servers (whilst WP also remains!).
It is installed, but WP is still running the website.
its frustrating. I’d start by checking recently installed plugins, user accounts, scheduled tasks, and any automated deployment scripts to identify what’s reintroducing ClassicPress. Also compare the affected installations to see whether they share a hosting provider or plugin. Checking server access logs may help pinpoint the source before removing anything
They are all my sites and I definitely didn’t install them.
look at some of the installs and look at the files to get the time they were created, see if there is a pattern. This might help.
Where is it appearing? I still don’t understand what you mean. Maybe post a screenshot of what you’re seeing?
After a bit more digging, the CP installs are all in March 25, which is probably when I came back to VIrtualmin from CPanel. They were WP migrations.
On all of those with CP, the WP install is shown as today.
They share the same, live, database.
@Joe the CP install is showing in
Web App Installers/Web App Summary
Server/Manage Web Apps
