I have setup a services monitor with a command to run when monitors go down. This has worked over the years for all services.
But recently I notice its not working for clamd. I am having clamd go down often on one server, but the command to run to restart it is not restarting it.
If I run the command from the command line it restarts fine
Do you know if Webmin is detecting that ClamAV is down? I’m curious if the problem is that Webmin isn’t detecting that it’s down, or if the command isn’t working for some reason.
